Where is a bookmark I added in iOS located on my PC?
When I add a bookmark in iOS it is located in the root directory, same place that Desktop Bookmarks is located. I want to know where the bookmark is located on my PC so I can file in in the right place. If I can't learn how to do find it in PC, I can't keep my desktop and iOS bookmarks synced.
Bookmarks saved on Firefox for iOS are not synced to desktop yet. They're working on adding that feature to a later version.
Ler a resposta no contexto 👍 2All Replies (2)
Hello, hope this can help
See bookmarks saved on your iPhone or iPad
Open the Chrome app Chrome. At the top right, tap More More and then Bookmarks. Tap the bookmark you want to visit.
See bookmarks you saved on a computer
By default, opening bookmarks on your mobile device only shows your mobile bookmarks. To get to bookmarks you saved on a computer:
Open the Chrome app Chrome. At the top right, tap More More and then Bookmarks. At the top left, tap Menu Menu. Tap the folder that has the bookmark you want to visit. Tap the bookmark you want to visit.
To share bookmarks across your computers and mobile devices, sign in to Chrome on each device. Signing in syncs your future bookmarks to your Google Account.
